Can you tune Fuel pressure by an A/F gauge?
Old May 12, 2005 | 01:15 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
As in, reading rich = less pressure
lean= more pressure
Old May 12, 2005 | 02:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Need an adjustable fuel pressure regulator.
https://www.thirdgen.org/newdesign/tech/o2tuning.shtml
Old May 12, 2005 | 02:23 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Not if you're still running the ECM controlled factory fuel setup. You won't be able to with an AFPR either. The O2 sensor will have that gauge swinging back and forth between rich and lean constantly (just like it's supposed to).....
Old May 12, 2005 | 03:39 PM
Car: 1971 Camaro
Engine: 427
I mean, use the A/F gauge as the measuring tool for seeing the car be lean or rich, need more or less fuel, and then making the needed pressure adjustments at the after market adjustable fuel pressure regulator?
Old May 12, 2005 | 03:43 PM
vernw's Avatar
I thought that's what you meant, but if the computer is in Closed Loop it will constantly be shifting back and forth between rich and lean. That's what it's supposed to do. If you unplug the oxygen sensor, you might get an little better idea but the car will probably run like old dried donkey dung and also set a check engine light/code.....
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
