vacuum hose help ASAP
Old May 14, 2005 | 01:36 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
What vacuum line attaches to this port with the little clips?
This is the hard plastic thing that has the hard plastic line going into the EGR valve, and another one going to the TB. I am trying to finish the car now, please respond if you know the answer. Thanks!
Old May 14, 2005 | 02:36 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: vacuum hose help ASAP
There's only 2, and those are already connected, that plastic thing is a solenoid, you need to find the electrical connector that plugs into it.
You can startup without it connected.
Old May 14, 2005 | 03:11 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
the electrical connector is plugged in, it is right behind the plastic nipple with the two metal clips in the picture. It looks like a vacuum hose should go on there. Does anyone have any close up pictures?
Old May 14, 2005 | 10:30 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
ttt
Old May 14, 2005 | 10:44 AM
rsn932's Avatar
the thing that looks like it should have a vacuum line going into it really doesnt. if you have the two connected, then youre all set. fire it up and if you just want to make sure, spray some starting fluid or carb cleaner at it and see if the idle changes.
Old May 16, 2005 | 03:45 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Those clips hold the *foam filter* over the little fitting there.
I was told you can buy foam for cheap at a craft store to replace it.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
