??'s on 24lb injectors and L69 heads on a Lb9
Old May 19, 2005 | 04:47 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
W/i the next 2 months I hope to have the following done:
Lt1 intake, headers, home-ported L69 heads, and 3.73 gears. Would I need bigger injectors then? My friend has a set of 24lb that he would sell me for cheap and I was wondering if I would even be able to use them.
Thanks.
Also, about those heads mentioned, I've read that they will increase compression but does anyone know by how much? I am interested in buying a set from a local guy and he could help with the bolt holes to fit on my car.
Old May 19, 2005 | 06:35 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
In my opinion 24lb injectors are too big. I think 21lbs will be a better choice.
Old May 19, 2005 | 07:00 PM
Iroc n roll's Avatar
I'd stick with the stock 19# injectors. You're not going to be making all that much more power than stock. At least not enough to need bigger injectors. Remember, the smaller the injector that can support a given horsepower the better. You want high pressure for better atomization.
Old May 20, 2005 | 12:31 AM
Car: 1994 Trans Am
Thank you guys for your replies. However something came up today that will put everything on hold for quite awhile.
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 07:20 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
