Tpi fuel rail with LT1 intake?
Old May 20, 2005 | 05:36 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
The LT1 intake I have doesn't have fuel rails. I've done a search to see if TPI fuel rails will work, and the spacing is the same for the injectors, but you'll have to drill-n-tap into them to get them work properly with the cross over pipes to match.
John McMillan, will this work? Can I do this at home, or not? I've never drilled and tapped anything before but it sounds simple? How can I plug TPI fuel rail crossovers?
Old May 20, 2005 | 08:50 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
you're causing yourself more work than its worth.... #1 the FPR will be in the way.. #2 the TPI rails where they cross over are straight.. the LT1's are angled(in the front)#3 the TPI fuel connections are in the front, LT1's are in the rear..check Ebay or www.camaroZ28.com for a set of rails.. usually can be had for 20$ or less.. got mine for 17$ plus 5$ to ship..
Old May 20, 2005 | 10:26 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Although with the fuel fitting in the front you won't have to lay out cash for new hoses, you could use the stock ones... there is one plus out of it.
Old May 20, 2005 | 10:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think his point was that the rails can't possibly be attached to the intake manifold with the TPI fuel lines there... Get a set of LT1 fuel rails.
Old May 21, 2005 | 12:34 AM
Car: 1994 Trans Am
Thanks guys.
midge54
Dec 27, 2019 04:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
