drive ability
Old May 20, 2005 | 05:44 PM
iroc&harley's Avatar
drive ability
hello. ihave 87 iroc the engine is a vortec 5.7 with 305 heads lt4 factory HOT cam stock tpi with 24 lb injectors . it surges from 1500 to 1900 rpm. there are no codes any body know of a cure?
Old May 20, 2005 | 06:09 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Re: drive ability
Well... that is a WHOLE LOT of cam for a stock tune/stock intake setup... which won't help any minor problems there are. I'd try to see what the ECM see's and go form there... maybe your running lean and knocking (ig. retard).
If that looks OK - which is all it will - you are way out of tune, check the TPS for any dead spots, etc. Does this happen all the time, warm cold, part throttle full throttle?
I doubt this will be easy to diagnose given your mismatched combination.
Old May 20, 2005 | 08:59 PM
thanxs for the reply . the tune up is fresh. the tps is new from gm,set up as per service manual. the car hits hard thru the whole rpm range. a little lopey at idle. would a new prom help? it is not a bad surge just noticeable. ive been a mechanic my whole life but this is the first chevy with fi that ive built.mosty street rods thanxs again
Old May 20, 2005 | 10:38 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: drive ability
...the engine is a vortec 5.7 with 305 heads ...
Anyone else doubletake on this or am I just too tired?
Old May 31, 2005 | 12:52 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Re: Re: drive ability
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
