Just Finished TPI Swap Car wont Idle.
Old May 22, 2005 | 05:44 PM
rustyZ28's Avatar
Car: 87 Z28
Transmission: 350 Turbo
I have an 86 Z28 with a 75 four bolt main 350. I just recently did a TPI sawp. I used a painless wiring harnes. The car want's to search for an idle 500-1500 rpm.
75 350 .040
Flat Top Pistons
Mellings Bumpstick
LSA: 114
Duration: 224 Intake & Exaust
Lift: .450 Intake and .461 Exaust
New Accel 24lbs Injectors
461 Doudle Hump Heads
10:1 Compression Ratio
New Knock Sensor
New TPS set at .54 V
New IAC
New distributor
New Coil
New AFPR
New O2 Sensor
New MAT
New CTS
New Coolant Temp
New Egr and Soliniod
No Trouble codes
New MAF
ALL New Relays
Any one have any ideas in why it would search for an idle speed ?
Old May 22, 2005 | 06:07 PM
rustyZ28's Avatar
Car: 87 Z28
I just adjusted the idle speed and it got the idle to smooth out but it idles at 1100 rpm. One other thing I my using a motorvation strip chip
Old May 22, 2005 | 07:12 PM
daveb8's Avatar
Did you try resetting the IAC. I believe every time it is removed from the throttle body it needs to be reset. Just search IAC on this site there is a good post on how to reset and adjust the idle.
Old May 22, 2005 | 07:42 PM
rustyZ28's Avatar
Car: 87 Z28
Yes i already did that
Old May 22, 2005 | 07:49 PM
Vader's Avatar
Do you know what the target idle RPM is programmed at? Your custom PROM may have a relatively high target idle for a long duration cam, plus extra IAC steps, in addition to the added IAC for a lower CTS reading. Is the coolant sensor working?
Old May 22, 2005 | 08:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think you'll need a little custom tweaking in the prom, you have more of a carb cam (low lift, long duration) as opposed to a tpi grind which favors higher lift and shorter duration.
Old May 24, 2005 | 05:09 PM
rustyZ28's Avatar
Car: 87 Z28
I readjusted the IAC and the TPS and no the it idles fairy smooth at 1100 rpm in park. Tonight I'm going to mess around the the fuel pressure, to see if i can improve the idle even more.
1nastygta
Oct 28, 2015 08:51 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
drathaar907
Aug 10, 2015 07:44 AM
