New injector size??
Old May 23, 2005 | 11:14 AM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
New injector size??
Dropping in my new 383 this week and need some help on What pound injectors to buy. Going with the stock tpi intake and runners. This motor is some what mild--9 1/2 piston and 420 lift, 240 @ 50 cam.
Old May 23, 2005 | 07:11 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
24 #/hr Ford Racing injectors along with a AFPR will get the job done for you. The stock ECM might be happy with these 24s. If you go any bigger, you will have to get an Eprom programmed.
Old May 23, 2005 | 10:54 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I say go with 30lbs injectors. I got 30's on my 327 an I got no tuning issues at all its not burning rich either. As a matter of fact my car fired right up with the new engine install and my cam has 292 dur. You do have a 89 with a Map though and it might not be as forgiving. I've had several people from forums, summit and other places say that there too big but I talk too a Dyno shop and they all agree to go with 30lbs and up. They say with their experience in dynoing that they get the best reading with them.
Also if you take a look at most performace cars today their sporting no less than a 28lb.
Old May 23, 2005 | 11:13 PM
iroczz89's Avatar
Engine: 383 tpi
Thanks for the info guys. I think i will go with the 30 lb ones lilbow. I have a guy that is going to reprogram my computer anyway.
Hey--where in N.C are you from?? My brother is the District Attourney in Gaston county---right outside of Charolette.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
