Difference between 85, 86and up harness
Old May 25, 2005 | 09:40 AM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
What is the difference between the two under hood harnesses? I did a search and could not find anything. This is what I have Thanks
Attached Thumbnails Difference between 85, 86and up harness-tpiharnessweb2.jpg
Old May 25, 2005 | 10:13 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
The main differences are the MAF burnoff sensor for the 85's and the relays used on the 86-89 stuff. Also, there is a difference in the "pinouts" on the computers. If you want to swap to an 86-89 computer, which I highly reccomend if you are using the earlier stuff, you will have to "re-pin" your connectors.
They have changed things around here and I finally found the link for information you will need....
General Technical FAQ's & Articles
Go to this link and search through all the useful stuff it may tell you what you want to know (besides what you have) and give you options to do a lot more.....
Old May 25, 2005 | 12:09 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
I think one of the things I noticed was that the 85 harness plugs at the ecm has 3 connectors. and the 86-89 has 2.
Jorlain
Aug 24, 2022 05:11 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Thomas
Oct 3, 2015 05:34 PM
Thomas
Southern California Area
Oct 3, 2015 05:31 PM
fbirdroller
Sep 2, 2015 10:27 PM
