Question about a H/C/I L98
Old May 27, 2005 | 03:45 PM
kylez28's Avatar
Car: 1991 z28 camaro
Engine: 350 TPI bored .060 over
Can I get some dyno and track numbers from you guys running H/C/I on an L98? I mean dyno and track numbers from a car that you drive on the streets daily or often. I'm thinking about the HSRintake/VortecHeads/LT4Hotcam set-up. My block is already bored .060 over and I have ram air, ported plenum, flowmaster exhaust, hedman headers, and a few other basic bolt on mods.
Old May 28, 2005 | 05:59 AM
kylez28's Avatar
Need a reply please, thank you.
Old May 28, 2005 | 11:05 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
here is a reply.
Kat
Old May 28, 2005 | 01:24 PM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Re: Question about a H/C/I L98
Originally posted by kylez28
Can I get some dyno and track numbers from you guys running H/C/I on an L98? I mean dyno and track numbers from a car that you drive on the streets daily or often. I'm thinking about the HSRintake/VortecHeads/LT4Hotcam set-up. ...
Well, I'd look at the Vortec small port dyno numbers in Hot Rod- or maybe Car Craft (I get them both- so I forget which mag had which article). They are fairly close to your set up- minus the HSR induction and the cam.
John Millican has some links that point you toward dyno sites for the HSR.
I'd go with the LT4 modified manifold and small port Vortec heads. With the cam, they would compliment eachother nicley. If I remember correctly, the newest Vortec heads have the FastBurn / old style bolt patterns too.
Then again, I could be completely confused as that I have already started drinking for today! Beer + Steak = ZEN
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
