Code 34
Old May 29, 2005 | 12:00 AM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Code 34
Any suggestions on what to look for on a code 34. I think it's MAF problem but i am not totally sure. And what will a cade 34 cause the car to do?
Old May 29, 2005 | 03:08 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Code 34
Code 34 deals with the MAF sensor (low voltage). I had a code 34, I replaced both the MAF power relay and Burnoff relay and it fixed it. Start with the small stuff before you go and buy a MAF sensor.
The first thing my book tells me is to look for a blockage/leak in between the TB and MAF sensor. Might want to try that too. My code 34 caused a terrible idle, and a really rich condition (blew grey smoke just at idle).
Old May 31, 2005 | 01:32 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Code 34
Old Jul 13, 2005 | 09:46 PM
midnightIROC's Avatar
Car: 88 IROC Z
Engine: 5.0 TPI
Transmission: 5 speed manual
This is probably a bit late, but I've been dealing with a Code 34 for the past year. I would only see the SES light at start up and if I let the engine idle for a minute, shut it off and re-start after about 30 seconds, the SES light would go away. However, this wouldn't happen everytime.
Anyway, I took the advice from this site and just bought a Power / Burn Off Relay, installed it today and I haven't seen the SES light since. For about $20 it was a cheap thing to try.
Good Luck
PS IROCThe5.7L, your car looks sweet. Mine looks just like it, except I've got t-tops.
Old Jul 16, 2005 | 02:20 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Replace the two relays. I paid about $13.00 each @ the dealer. Even the GM manual says if you get a code 34 do not assume a MAF problem. Its more common for the relays to freeze, especially on vehicles that sit for the winter. Alot cheaper at $26.00 to!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
