Car idles poorly when cool
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have an 86 TPI 305 and there's a slight idle problem with the car. Basically, it idles poorly for about 30-60 seconds after started. When I first start my car, if I don't tap the gas then my car's idle will drop to about 400rpms and stumble a bit. Once I press the gas it will catch itself and shoot up and act normal. And once the engine warms up a little bit the car runs absolutely perfectly. I'm not really sure where to look or what would cause a rough idle until the car warms up.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Follow the tech article to clean your TB and set your IAC and TPS then proceed from there
later
Jeremy
later
Jeremy
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I have the same problem, people are always saying IAC, but can someone tell me why it would be the IAC if it only happens when it is cold, I thought IAC would be for all the time. Please help us
Edit: I have decided to just go out and buy a new IAC, it seems to be the only thing that hasnt been done to fix my car so it must be it. I will be installing it some time this week.
Replacing the IAC wont do a @#$ thing unless you follow the proper procedure to set the IAC and TPS and that the car leanrs it.
There is an excellent tech article here that will easily show u the proper way to set them both.
later
Jeremy
later
Jeremy
Engine: 388 Carb
Axle/Gears: 4.10
so is there a way to diagnose if it is the IAC or not, I did all of those things in the tech article. It helped a little but not alot.
