Cleaning Fuel Injectors
Old May 31, 2005 | 10:18 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Has anyone cleaned a set of fuel injectors by soaking the tips in a jar of BG(yellow cantener $20 stuff cleans injectors when you put it in a tank of gas) if any one has done this how long should i soak them 24 hours? I don't think it will harm anything, maybe not even help if anything. I Plain on running this stuff throw the gas tank too afterwards. Since i'm doing a intake job i was going to soak the injectors, I never really had a problem with them, if i had the extra cash i'd get them flow balanced and stuff.
I was thinking too about running 12 volts to them for like 2 seconds at a time with some sort of cleaner pumping cleaner in them. but i rather not burn them up or use the wrong cleaner and destory the inside of them.
Old Jun 1, 2005 | 04:22 PM
brutalform's Avatar
If you had no problems, then why bother? Someone correct me if I'm wrong, but would hitting them with 12 volts ruin them?
Old Jun 2, 2005 | 09:08 AM
8UpAFord's Avatar
Car: 1988 Corvette
your right i reaseached it i need less then 12 volts, Might hook up a bulb in the same circuit to pull down some of the voltage.
Old Jun 2, 2005 | 06:09 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
just do it right by sending them to Rich @ Cruizin Performance.Have him flo-match them while your at it.I've had him do 2 sets of 19# injectors plus the 22# one's that I'm running now.
Old Jun 3, 2005 | 09:34 AM
8UpAFord's Avatar
Car: 1988 Corvette
I just did my cleaning yesterday. It went very well. i injected 3oz of cleaner in first. then about 10oz of rubbing Alchol to all 8 injectors. They all where clean not any sign of diryness in them. I think they are pretty new or Shell 93 really works as good as they say it does.
I freekin lost my fuel pressure gauge, so i need to buy one today. i slapped a fuel pressure regulator. I need to be able to start the car if i screw down the screaw will that give me higher or lower pressure? I think higher as it tightens?
Thnaks
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mdtoren
Aug 23, 2015 12:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
