Need help from Pontiac owners years 88 and 89.
Old Jun 1, 2005 | 09:32 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I've been trying to get my car back to normal with a serpentine setup off of an 88 TA. The only thing left...the air filter canister is not sealed to the rest of the intake. What's supposed to keep it sealed? Clamps? I got the stuff from Hawks and still can't figure out how to keep it sealed.
Old Jun 1, 2005 | 10:05 AM
Car: 1987 GTA
Transmission: 4L60e
Problem lies in circled area ->
Attached Thumbnails Need help from Pontiac owners years 88 and 89.-help3.jpg
Old Jun 1, 2005 | 11:25 AM
Damon's Avatar
Looks good to me. I beleive there is a large hose clamp that goes around the duct work flange and holds it tight against the metal neck sticking out the top of the air filter housing. Not much more complicated that that.
Old Jun 1, 2005 | 11:32 AM
Car: 1987 GTA
Transmission: 4L60e
Yep - that piece is secure. What I'm interested in is the "metal neck sticking out the top of the air filter housing." This piece on mine just sits loose. What secures it?
Old Jun 1, 2005 | 12:08 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
There is a long bolt that goes down thru the center of the brace across the top of the lid and bolts into the body thru a matching hole in the bottom of the canister. Then when you LIGHTLY tighten it up it presses the lid onto the rest of the canister.
I said "LIGHTLY TIGHTEN" because uf you crank down too hard it starts collapsing the air filter.
At least that's how it works on my '91 Bird.....
Old Jun 1, 2005 | 12:14 PM
Mark 89Formula's Avatar
My stock setup used spring clamps (3 or 4) to hold the lid to the body of the cannister. It's been off the car for 12 years so I'm going from memory. I can pull it off the shelf for a closer look later tonight if that would be helpful.
Old Jun 1, 2005 | 12:22 PM
Car: 1987 GTA
Transmission: 4L60e
That would be very helpful. I'm fairly certain it's not the long stud type (I've had a 91 GTA and know what you're talking about). Guess it's time to start hitting junkyards looking for clamps.
I couldn't get these at a home supply store could I? Perhaps an auto parts place?
Oh - and Mark: check the South Central regional board for information about Houston Thirdgen get-togethers. If you haven't been you're really missing out.
Old Jun 1, 2005 | 06:44 PM
Ok, there's 3 clamps attached to the cannister that hold the lid on. If you don't have those clamps, I don't think you have the 88-89 style cannister. Drop me an email and I'll send you some digital photos of the original setup from a few angles.
Haven't checked out the South Central board so I'll have to take a look. Job and family just doesn't leave much time for the car though and the exterior looks like a POS so I'm not in a hurry to show it off.
Old Jun 1, 2005 | 07:18 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Hey 3.1 show us a close up pic of the top and inside of the air filter housing so that we can better understand what it is you are working with the housing differ between the v/8's and v/6's on some years.
My car had a 1 inch bolt that tightened the bottom of the canister to the body then the top was clamped with 3 clamps.
Old Jun 1, 2005 | 09:56 PM
Car: 1987 GTA
Transmission: 4L60e
Both of you guys are on the right track. I've got a one inch bolt that tightens the metal bracketry to the car and the rubber tubing itself attaches with a large hose clamp style connector to the "large upper metal neck" piece. I don't have a digital camera to use currently and so can't attach pics. I'll do some work in paint and attach that here in a bit.
Old Jun 1, 2005 | 10:02 PM
Car: 1987 GTA
Transmission: 4L60e
I need to secure the upper air filter canister section to the lower. Hopefully this pic will help.
Attached Thumbnails Need help from Pontiac owners years 88 and 89.-help4.jpg
Old Jun 2, 2005 | 07:10 AM
Dustin89GTA's Avatar
Car: 1989 GTA
Engine: 355 TPI
Transmission: 700R4 (w/ shift kit)
Axle/Gears: 3.27 (stock)
There should be three clips around the perimeter to hold the top to the base. That's the way mine was before I removed it.
Old Jun 2, 2005 | 07:27 AM
palmeris's Avatar
Car: 88 FB GTA
Engine: 5.7 bored to 355 and some other mods!
yes 3 hinge clips that are permant on the lower can and they snap down to clamp the upper lid onto the lower can
Old Jun 2, 2005 | 07:28 AM
Car: 1987 GTA
Transmission: 4L60e
Keep hearing people say they removed theirs. Anybody wanna sell their leftover parts?
Old Jun 2, 2005 | 06:53 PM
robsgta's Avatar
As long as your filter is secured to the tubing I wouldnt worry about it. Most so called cold air kits have a open K&N air filter secured to some fancy smancy chrome tube for about a hundred bucks..
Rob
Old Jun 2, 2005 | 07:10 PM
Car: 1989 GTA
Engine: 355 TPI
sure, I'll see if I can find it. It's in a garage about 4 hours away though.
Old Jun 2, 2005 | 10:06 PM
Car: 1987 GTA
Transmission: 4L60e
heh...guess its junkyard diving time then. And about it being secured - that's the problem - it's not. Right now I've got a bungee cord holding it tight.
Thanks guys! I've narrowed my search alot.
Old Jun 3, 2005 | 10:51 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
PM'd ya. I have my stock air filter setup sitting in my garage, letmme know if you're interested.
colton_carlson
Mar 8, 2019 12:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
neekolzun
Aug 24, 2015 04:59 PM
