Intake seals.... please check this out...
Old Jun 2, 2005 | 06:19 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Hello,
i m currently busy with replacing the
intake seals...
but the new intake seal has
a iron/metal plate in the seal itself.
is this normal ?
the old one don't have the iron/metal plate....
should i remove it or leave it ??
see below...
let me know ASAP thanks
Old Jun 2, 2005 | 06:59 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
If you take a look at the opposite side of the metal tab you will see that their isnt any thing there the water wont travel through your intake where the metal is so dont worry about it..
You might want to just use a thick bead of grey silicone on the front and back of the intake on the china wall instead of using gasket material( the cork or black rubber material) they usually slip out and move over time. Be sure the mating surfaces are very clean as well.
rob
Old Jun 2, 2005 | 07:15 PM
GTA89's Avatar
Engine: 5.7 350
rob
Yeah,
thank you,
i already noticed that, the front and the back seal
i will use the sillicone kit...
thanks a lot !
Hellbillydeluxe
Sep 22, 2015 09:58 PM
1992Vortec
Aug 31, 2015 08:05 PM
Out-Cast
Aug 17, 2015 10:57 AM
