Do I need special intake gaskets for LT1 intake?
Old Jun 3, 2005 | 01:58 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Or will any 88+ SBC intake gasket be fine? Also, bought the manifold on ebay and it comes with modified fuel rail/ accel FPR / and remote thermostat. Besides the return hoses from the thermo to the manifold, what else will I need?
Old Jun 3, 2005 | 02:02 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Regular SBC intake manifold set.
Old Jun 3, 2005 | 10:51 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Use 1979 and earlier Camaro intake gaskets if you want cheap. They don't have EGR ports in them.
Old Jun 4, 2005 | 03:19 AM
Car: 1997 Corvette
D'oh, yeah, what he said. Don't want the EGR ports on there because the LT1 intake doesn't have em. You lose your EGR function when swapping to LT1 intake.
Might not be a good idea for you in Arizona, I hear they visually check for EGR. Look into getting the setup off an LT1 'vette. I believe they had an external EGR setup. All you need to do is make it APPEAR to be working, and then get a chip burned to disable EGR in the computer or you'll throw codes.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
mizz0313
Aug 12, 2015 06:45 AM
