Possible leaky injectors?
Old Jun 5, 2005 | 08:25 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
ok i did some research as I know, we teach that well to our members. My car has trouble starting and smells really rich of gas in the exhaust. I have to give it gas in order for it to fire up and usually takes anywhere from 5-15 seconds to fire up. Alot of people pointed to injectors leaking. I know its not the starter cause i had one go before and it's not it. I am also aware that the injectors do tend to fail from what i have read. Can someone just confirm this for me or point me in the right direction?
Old Jun 5, 2005 | 08:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You'll have to start by getting a fuel pressure gauge and checking the leak rate.
You can also get a fuel injector cycler to test each injector while on the car. (still need the gauge).
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
