Quick rocker question
Old Jun 8, 2005 | 10:10 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I'm currently looking at Comp Cams Magnum steel roller rocker arms (Summit part # CCA-1417-16) for my 1989 L98.
Since these are 1.52 ratio, will they work with my stock heads & cam?
Is there any real gain with going from a ratio of 1.5 to 1.52?
Any info would be greatly appreciated.
Thank you!
Old Jun 8, 2005 | 11:04 AM
brutalform's Avatar
I believe they are 1.52, and they are referred to as 1.5.
Old Jun 8, 2005 | 12:52 PM
Guest
Guest
Posts: n/a
Stock rockers are 1.5, at least thats the calculation GM uses between lobe lift and valve lift.
Any difference? Probably not much and I wouldnt expect much, like 5hp. You will gain a little from less friction, a little from the ratio change, and a little from having accurate ratios rather than the factory fix+match of stamped steel.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
