Fuel Pump suggestions
Old Jun 24, 2005 | 08:45 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have done a search and really found nothing specific to what I am wondering. What FP do you recommend and which to avoid.
As it seems my FP has stopped running I am going to check the FP relay (hopfully thats it, although it still clicks when I turn the car on. If not it I am doing the Fuel Pump Swap this weekend.
I DO NOT WANT INFO HOW TO CHANGE IT.
I did notice however that some people have problems with some brands of Fuel Pumps. WELBRO is one that seems to whine. Is there any Fuel Pump that you swear by as being great and others that are junk.
Should I go with a GM one? I figure the OEM one lasted 200,000 miles, as that was the milage of the car I got my TPI off of.
I have a basically stock engine for all intents and purposes.
John
Old Jun 24, 2005 | 10:16 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Do not buy a fuel pump from any local parts store. Only use an orginal fuel pump from the dealer or a Walbro. I as well as many people on this board have Walbro and they are very good.
Old Jun 24, 2005 | 10:23 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
use either a AC delco pump, or a walbro.
somepeople say the walbro makes more noise then stock.. ive never noticed it on the 255 pumps..
but like you said, you have a stock car, so might as well get a stock AC delco pump.
DONT get the cheapie whatever they have at the store.
and get a AC delco fuel "sock"... not a cheapie.
Old Jun 24, 2005 | 10:25 AM
okfoz's Avatar
Ok, So a Delco it is thanks.
BTW, I have found part numbers 10094701 for the Relay and 25116163 for the Pump, does that sound correct?
John
Old Jun 24, 2005 | 10:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i have a box sitting at home from when i swapped pumps in the new beater....
but to be honest, i just use what the computer says.
Old Jun 24, 2005 | 11:06 AM
okfoz's Avatar
Thanks guys, I just wanted someone to hold my hand.
I got a Delco FP, Delco strainer, Delco Filter and a Delco Relay. I figured I will cover both ends I can't go wrong . I guess for $100.23 it ain't bad... I am not looking forward to it tho .
Like I needed a good project.
John
Old Jun 24, 2005 | 11:32 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
I would recommend the following kit:
RaceTronix
Old Jun 24, 2005 | 12:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
RaceTronix
if you're running a aftermarket pump, or have a modded motor, thats not a bad idea... you do get alot of voltage drop with the stock setup.... but for a mostly stock car, its overkill and a waste of money.
Old Jun 24, 2005 | 12:33 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Agreed....I use the LT-1 replacment pump and it has 31gph vs. stock 18gph anything more than that for a slightly mod setup is a waste of money. I too, have had issues with the Walbro overkill pump...why, it is not needed for most applications.
Old Jun 24, 2005 | 02:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
what issues have you had with the Walbro? one of the reasons i love thoes pumps is that i know of NOONE who has had one fail, except by their own fault (guy didnt put the sock on it, and it ingested alot of rust)...
the only complaint i know of is that they whine
Old Jun 24, 2005 | 02:21 PM
okfoz's Avatar
Here is my setup:
Chevy 312 (305 .040 over)
9.5:1 Compression
Holley AFPR
SLP Mild Cam Part # 51002, Duration: Int 258 Exh 264, Dur @ .050: Int. .206 Exh. .212, Lift Int. .480 Exh. .487, Centerline 112
SLP Ceramic coated Headers & 3" SLP Cat back
1 3/4" oversized runners
About it.
I think the stock one will do me well enough... I would like to hit 14 sec 1/4... but we will see when I start programming again.
John
Old Jun 24, 2005 | 02:23 PM
okfoz's Avatar
I think he believes its overkill is all, its a good pump and all.
John
Old Jun 24, 2005 | 02:33 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
John
ok, gotcha.
it is overkill unless you need that much fuel flow...
(athough, some of us do.... )
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
