edlebrock hi flo siamesed and ZZ4 cam dyno
Old Jun 25, 2005 | 03:17 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I just figure I'd toss it up to compare for others
B2L 353 ... stock rebuilt heads with mgnum rockers and studs . 3 angle valve job. ZZ4 camshaft . Forged pistons , stock rods , crank. Edlebrock hiflo intake with the runner siamesed in 4 " base . Just cleaned up a bit of casting crap . Stock 1989 vette 6 speed prom. 34 degrees out today ( LS1's were 20 hp lower today )
I will post the graph when I can get the dam scanner figured out
but I got 251.3 rwhp and 319.8 RWTQ
she peaked at 4500 and lost 20 hp at 5600 . Not to bad though . I was happy with it I only expected max to get 245 to the wheels
Old Jun 25, 2005 | 07:27 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Your dyno numbers should have been converted to SAE figures. Otherwise hard to say about your numbers. You have quite a few mods and I would think a custom eprom would be in order to achieve maximum power out of your combination.
Old Jun 26, 2005 | 12:13 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Thanx man . I am not sure how to do the conversion ....
Old Jun 26, 2005 | 11:21 AM
Car: 1989 GTA
Engine: 369 TPI
The dyno operator does the conversion to the SAE numbers. Look on your dyno graph and see if it says SAE on it by the Horsepower and torque numbers. Allen
Old Jun 26, 2005 | 02:29 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Yup it was SAE numbers . Was that a good thing then ?
Old Jun 26, 2005 | 02:35 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Was it a dyno-jet or mustang dyno?
Dyno jets tend to make more hp per car at the wheels than a mustang dyno.
If it was dynojet, u need to start working on the tune , alot.
I made 225rwhp and 315rwt on a dyno jet with a stock 91 350TPI GTA.(car was at 220 for the run)
Mods were 24# injectors and SLP catback with my own tuning.
Your only picking up 25hp and 5ft lbs over my best stock. U added a cam, valvlejob, full exhaust and less loss to the rear wheels because u have a manual.
Not slamming it by any means, just think there is more there for u to unlock thru tuning.
Great starter articles on the prom board if your not familiar with it.
later
Jeremy
Jorlain
Oct 8, 2015 01:57 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
89fast5oh
Sep 8, 2015 09:55 AM
Strick1
Sep 4, 2015 07:11 AM
