fuel pressure woes
Old Jun 26, 2005 | 03:06 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
fuel pressure woes
I just got done swapping out the fuel filter, fuel pump relay, fuel pump is going on 2 years old, I also put in a TPiS afpr 2 years ago. With the ignition on its not priming up the fuel rail, makes for difficult starting. When I turn the key from off to run I can hear the pump engage for about 2 seconds but yet I still have 0 psi at the rail. Once the car is started the pressure is up 45psi without the vacume line. With the vacume line hooked up it reads around 38-39 psi. When I get on the throttle it will jump up to around 44 psi then when I get off the throttle it will go down to about 36psi for a few seconds then back up to 38/39. Im just baffled as to why it doesnt prime the rail with the ignition on I can hear the pump try to prime for a couple seconds. Does this sound like normal pressures? I checked the fuses in the fuse box there is no fuse for the F/P ctrl, no brass terminals even in there for a fuse. So I presume it uses the INJ2 F/P fuse and it looks like a perfect 20amp fuse. Im not real sure as to what to try next.
Old Jun 26, 2005 | 04:39 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Ok I just put 12 volts to terminal G on the ALDL and fuel pump kicked on, read about 0 psi at the rail. I then pinched the return line and it shot up to a lil over 40psi. I took the air duct work off and open up the throttle blades to see if I could hear an injector leaking and didnt hear any hissing or anything of the nature. So this leads me to beleive its the fuel pressure regulator diaphram?
Old Jun 27, 2005 | 07:25 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
heh allright i guess i answered my own questions. I poped off the fuel pressure regulator this afternoon and found a nice little suprise. There was a little chunk of what apeared to be a orange peice of plastic sitting in the bowl underneeth the regulator. Slapped the new one in it anyway while I had it apart and seemed to fix the fuel pressure issue. Now I can go back to hunting down the code 44.
Old Jun 28, 2005 | 02:08 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i had the exact same problem, and i fixed the FPR and now im still trying to find out about the code 44!!!!!! let me know if you found out what it was yet thanks a LOT
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
