TPS adjustment screw rounded out. Replacement screws?
Old Jun 29, 2005 | 01:30 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Where can I get a new set of two screws for my tps sensor? One has been rounded out and I can no longer safely loosen or tighten it. Would a new sensor come with them? Thanks
Will
Old Jun 29, 2005 | 09:02 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Take one out and match the threads at Home Depot and spend a few cents for a new one. If you can't find one with a matching head, buy two if you think they need to match.
Old Jun 30, 2005 | 03:20 AM
big black bird's Avatar
Car: 1989 transam
Engine: 350 hsr trickflow twisted wedge g2 comp cam 490 lift haltech e6gm ,33lbs bosch injectors
Transmission: t700
do a search on this topic as i can remember one of the guys retaped the throttle body to a more common size thread i did it my self and it worked great threw away those bolts made out of aluminium garbage that snap so easily from what i can remember the size was 10/32 but not 100% sure with the size tap
Old Jul 5, 2005 | 01:02 AM
Pat Hall's Avatar
I don't know if TPI throttle bodies are the same, but I snapped off the TPS screws on my 89 TBI unit (they're the same cheap aluminum crap). I took it to a machine shop to have the screws drilled out and removed without screwing up the threads. After they got the old screws out, they called me and told me the original threads were some screwy french-metric size, and they'd have to special order an expensive tap. The screws themselves were also a special order item that were ridiculously expensive too. I ended up going to the local nut and bolt supply, and they sold me two stainless steel allen headed screws and washers, and a SAE machine thread tap (can't remember the exact size). Anyways, all this only cost me like less than five bucks, the screws are a common thread size and way stronger, and I haven't had a problem since. Just my .02.
Old Jul 5, 2005 | 11:14 AM
brutalform's Avatar
Try this. AC Delco screw kit. These #s are on the box.
761D7
1 #17112369
GR.3.336
Made in the U.S.A. BTW the TPS screws you cant buy. They have a weird thread pitch.
I bought this about 3 years ago, maybe they still stock it. You"ll get the TPS, top plate, and IAC housing screws....Good luck.
Old Jul 6, 2005 | 07:57 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Most of the new ones you buy at the parts store come with new bolts.
Old Jul 6, 2005 | 09:41 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I remember reading the problem with locating these screws away from the dealer is that they used a weird bolt size. Something like 4.5 mm, not sure what the pitch is.
dcbsracing007
Aug 18, 2015 07:24 AM
perZ
Aug 15, 2015 01:17 PM
TheJoeY88
Aug 13, 2015 06:51 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
