85tpi ecm swap to 86ecm?
Old Jun 29, 2005 | 01:41 PM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
i know there is a tech article out for this, but other than data logging because the faster sample rate, does the engine run more efficiently, hp, torque, mileage?
Old Jun 30, 2005 | 12:52 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That I don't know, but it does give you the ability to run a much less expensive MAF sensor, plus, if you plan on tuning the prom, there's probably much better support for the '165 ECM.
Old Jun 30, 2005 | 09:01 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 85tpi ecm swap to 86ecm?
For the effort that it takes to convert to the later ecm, IMO, it's worth just a little more work to go to the 90+ ecm, and swap to MAP.
For some folks, they're happy with the 85. If your not really into making the best of things, the changes might not be very prevalent to you. In general the newer the code, the better the car runs, but *better* is in the eyes of the beholder <g>
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
