Fuel pump output?
Old Jul 4, 2005 | 04:06 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Fuel pump output?
I am doing the carb to TPI swap and I am opting to use an inline electric fuel pump because my exhaust is completely welded and I don't want to cut it. I see Holley has a myriad of different PSI, GPH outputs but what exactly does the 305 TPI engine require? thanks
Old Jul 6, 2005 | 11:59 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
If you're going to an in-line pump, it will need to supply at least 50 psi and 16 gph.
The Holley 12-920 fits the bill, but it's expensive.
You might try looking at http://www.autoperformanceengineering.com/.
Edit: Look at the MSD-2225 at Summit Racing.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
