Loud hiss when revved
Old Jul 6, 2005 | 10:33 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
So last night i tore down the tpi (pia broke 2 torx bits) and installed 4 new injectors. I got her all back together and she runs like a champ very smooth good idle ect. The problem is when you rev the throttle quickly you can hear a loud hiss and there is a delay, we sprayed around the runners and obvious possible vacume leaks with carb cleaner but heard no change in the way it ran. So anyone have any ideas on something i may have overlooked or a usual culprit?
Old Jul 6, 2005 | 10:51 AM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
I can appreciate the teardown - I recently had to change an intake manifold gasket for a water leak.
As for the hissing sound, double check all the small vacuum lines - there are a lot to remember to re-connect and I bet one might be loose, from under the plenum or other. I guess, I'd just double check that first.
Kev
Old Jul 13, 2005 | 01:06 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Alright guys pullin my hair out here, pissed with it for a while with no luck. Does anyone have a Vacume diagram or any good ideas, have already sprayed carb cleaner everywhere a few times and tried the rubber hose to the ear trick. I even tried to disconect each line from the plenum one by one and plug the hole with my finger and rev.
Old Jul 13, 2005 | 01:40 PM
Steve89GTA's Avatar
Did you use new runner gaskets?
Old Jul 13, 2005 | 01:48 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
No but the ones on there seemed to be in good shape.
Old Jul 13, 2005 | 03:27 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
change them ...I had the same issue .
Old Jul 13, 2005 | 03:41 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Top bottom or both, is there some type of sealer that is good to use?
Old Jul 13, 2005 | 05:09 PM
Guest
Guest
Posts: n/a
Power brake line hooked up?
There's also the PCV hose to the driver side on the base.
Old Jul 13, 2005 | 05:54 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
RTV is the sealant that it calls to use.
Old Jul 13, 2005 | 10:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No sealant needed or called for on runner gaskets, use new ones though, they compress to seal...you notice the difference when you get the new ones.
Not sure if it's your problem or not, though...carb cleaner should have brought poor sealing to your attention.
Did you hook up the little tube under the Throttle Body?
Old Jul 14, 2005 | 08:42 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I sprayed around the runners good with no noticable difference, and yes i did reconnect the hose under the throttle body/plenum, power brake hose, and the pcv hose.
Old Jul 14, 2005 | 09:24 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Could you describe the "delay" a little more? Does the hiss lag behind the throttle moving? Does the engine delay revving from the throttle moving? Does it hiss when revving up, or when returning to idle, or both? Does it really sound like the intake is hissing?
Try a length of hose put up to your ear to try to locate the source.
You still have it MAF, right, not converted to SD (and revving without an air intake - the IAC has loud flow through it)?
Since it doesn't idle really high, i'll assume you have the runners on the correct sides.
Did you remove much else besides the runners, plenum, TB, and rails?
Old Jul 15, 2005 | 09:17 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
The hiss does lag behind the throttle moving and it delays the motor from revving, it only does this when romped on . At no other time is it even noticable. O and no its not coming from the intake.Yes it is maf, and the only other thing i changed was the ignition module. I did also try the hose trick.
Old Jul 15, 2005 | 09:50 AM
Did you get the tranny's TV cable hooked up and adjusted correctly (fully retracted, then hooked up, then WOT)? Is it your transmission hissing (and burning up)? I don't think a loose TV cable will cause the engine to lag, though - from what I've seen it revs faster due the slipping clutches.
Are you romping on it by hand in the engine bay, or while driving? TV cable won't matter if it's in Park.
It's a strange problem... Does it feel like it lost any power? Did you put in 22lb/hr injectors?
Old Jul 15, 2005 | 10:21 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
It does it while in park, and i am doing it by hand under the hood, i drove it around the block one time and it just didnt feel as responsive as it should. And yes they were 22lb injectors, i also tested resistance on all of them before putting it back together, all were 16.5 ohms or higher.
69GTOby
Apr 18, 2016 02:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Giocio
Oct 1, 2015 12:20 PM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
