My TPI swap - what ya think so far?
Old Jul 9, 2005 | 08:09 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
I am doing a carb to TPI swap and I started with an 86 TPI system off of Ebay. The guy was close and the price was right. I have gotten parts from many of you on this board and thanks for each of yours help - I needed it. I am in no way getting close to done but wanted to post my polished plenum. I ported the inlet where the throttle body connects. I tool the butteflys out of the TB and cleaned out 19 years of YUK! I took my intake, Plenum and runners to a machine shop and had them hot tanked to remove all the build up. It was worht the $30 bucks. The EGR holes were completly clogged, and the small holes just inside the plenum for the EGR was plugged with carbon as well. I am about 80% complete with polishing the Plenum and half way complete on one of the runners. One picture is a nice comparison from stock to polished.
If you have any suggestions or complaints (but tell me how to improve if it is a complaint;-) let me know.
Old Jul 9, 2005 | 09:03 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
nice
Very clean setup. Have fun with your new torque monster.
Old Jul 10, 2005 | 11:10 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Remember to check the 4 center holes on the intake if putting this on an 87' or newer engine. They are at a different angle and you don't want to find out on the day you're installing it.
A dremel with one of those "rot-zip" bits worked like a charm for mine. Ground on one of the holes for about 40 minutes then changed to that bit and did the other 3 in 15 minutes.
good luck with it
Also when I did mine I polished the fuel rails and painted the grooves with paint to match my car (same with the top plenum grooves)
The "color-chrome" spray paint looks pretty good for doing that and doesn't come out looking like paint.
Putting a silver high temp base coat on other parts you want to color make it come out nicer too.
Here's a pic of what the color comes out like.
Old Jul 10, 2005 | 11:11 AM
JP86SS's Avatar
Attach the picture
Don't know why it came out so small ???
bigger picture here with others.
https://www.thirdgen.org/techbb2/sho...hreadid=307048
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
