Fuel Pump or Regulator?
Old Jul 17, 2005 | 12:43 PM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Here's the story:
Stock 87 TPI, no bolt-ons, Walbro 340 fuel pump installed last year. I have a fp gauge mounted on the rail, and it used to fluctuate around 38-42 while running. The other day, the car pretty much felt like it gave up comming in from a long drive(more than 1/2 tank of gas) and ther fuel pump was pretty loud. It stalled comming into the apartment complex, was able to restart the car, but it ran like crap. I was not able to give it any gas or it would stumble and die again. The fuel pressure gauge was showing a steady 31 psi on the rail. When I went to try to start it this morning, it had 31 psi still, after priming the system. I turned it on, and it seemed to idle fine. I clamped the return line with some visegrips and the pressure went to 34 psi. I disconnected the vacuum line and the pressure went up to 32 psi. While reving the car, I get maybe 33 psi at the most. Is this a fuel pump issue or a regulator?
Old Jul 17, 2005 | 01:19 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
clamping off the return line should have jacked the pressure way up to well over 70 pounds.
you have problems with either fuel pump or maybe the rubber hose on the fuel pump.
it wouldn't hurt to replace the fuel filter, odds are its not your problem, but it is possible.
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
