Camsaft
Old Jul 17, 2005 | 03:08 PM
jape's Avatar
Car: pontiac firebird trans am gta-88
Engine: 350 tpi
Transmission: th700r4
Camsaft
I am looking a new cam my 5,7 tpi engine and i think lt4 hot cam is good but is this works with stock computer?
Tpi engine has long type intakemanifold+runners is this works with hotcam?
Old Jul 17, 2005 | 10:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
no and no, as i have done my research for this same cam, the ecm will have to be worked and the heads cant handle anything over .500 lift. (lt4 is .525 w/ 1.6 rockers) and if you use the 1.5 rockers for the .492 lift, the heads should be fine but then the press in studs might not..
Old Jul 18, 2005 | 10:51 AM
jape's Avatar
Engine: 350 tpi
Thanks,must see som other cam.
steven
Apr 5, 2001 11:54 PM
