Help!!! with sensor
Old Jul 19, 2005 | 11:46 AM
#32pontiac's Avatar
Car: 1988 Pontiac GTA
Engine: 350 TPI, With roller lifters
Transmission: 4 speed 700r4
Help!!! with sensor
I have 1988 GTA with the L98 in it, My question is the fuel pump relay sensor suppost to have power to it when you turn on the key? I unhook it and put a power light on it and the light does not come on. PLEASE let me know, and thank you.
Old Jul 19, 2005 | 11:52 AM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
I would have to say yes it should have power to let the fuel pump prime . before starting.
Old Jul 19, 2005 | 12:04 PM
#32pontiac's Avatar
So I hooked up some out side power connection and the fuel pump started to run, Why then do you think it will not run on its own?
Old Jul 19, 2005 | 12:21 PM
Axle/Gears: 373
bad wiring ? hook up power to the relay and see if it's good?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
