Injector size and tuning? Too big too much fuel?
Old Jul 28, 2005 | 01:26 AM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I don't understand how these fuel injectors work, I see guys with 42lb injectors with 400hp and I see people with much smaller injectors making just as big of numbers.
I thought injectors were like carb cfm...
I'm looking at some 42lb injectors, but I am afraid they will be too big for my application (blown 350)
How about tuning? how much of an issue is tuning with larger injectors?
Old Jul 28, 2005 | 02:51 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well, first thing u need to do is you basic math to determine your injector needs. I dont have it off the top of my head but on turbo/super engines, basically use a bsfc of .55.
42# wouldnt be absurd at all on a 350 with 12-15psi of boost, depending on the overall package.
Somethings to note when changing injectors.
Chip burning will be mandatory, u will have to accomodate the Injector Constant for the larger injectors as well as haveing to play with AE and some other stuff. Again alot depends on the whole package and how you end up doing it ie, intercooled or not, run a factory boost sensing ecm like the 749(highly rec) or using an FMU(not the best way)
Hit the Prom board for alot more info about injector sizing and what to look for as well as real solution to running boost reliably using factory ecm's, not band aids like fmu's and retard boxes.
later
Jeremy
Old Jul 28, 2005 | 01:19 PM
brutalform's Avatar
[QUOTE]Originally posted by 3.8TransAM
[B]Well, first thing u need to do is you basic math to determine your injector needs. I dont have it off the top of my head but on turbo/super engines, basically use a bsfc of .55.
Horsepower X BSFC
# of injectors X 0.8
This should get you in the ballpark.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
ezobens
Aug 19, 2015 10:29 PM
knight72
Aug 10, 2015 09:32 PM
