estimate my hp???
Old Jul 27, 2005 | 02:54 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
estimate my hp???
i have a stock bottom end l98, trick flow specialties 23degree alum heads with the 1.4 valve springs, super ram runners/plenium, lightly ported edelbrock tpi high flow base, crane cams double roller chain, lt4 HOT CAM, valve spring, 1.6 full roller rockers, headers, n10 dual cats, and 6speed
estimate redline, estimate hp
Old Jul 27, 2005 | 09:51 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
redline should stay the same as it was from the factory if its still got the stock bottom end..
Old Jul 28, 2005 | 02:07 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Seems like I have seen another setup like this and it was about 360 to 375 fwhp.
Old Jul 28, 2005 | 02:21 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
This was my exact old combo. It made 275 RWHP and 326 RWT. This was on the stock PROM and in 100*+ degrees outside. 1/4 times with stock converter also was 13.4@104 at Red River Raceway in LA
Old Jul 28, 2005 | 02:42 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
no, the only part that sets the redline would be cam, intake, valvetrain ability, basically i took care of the valve float at 5,800K so it should theoretically probably should be fine until about 7K bottom end is fine
Old Jul 28, 2005 | 05:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I say go for it
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
