I need a new fuel filter
Old Jul 29, 2005 | 10:10 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Can anyone tell me what aftermarket fuel filter will work for tpi?
I was using a big Fram filter that I had mounted to the right front engine block just under the alternator. When the fuel reached the filter it split the case at the inlet line. I would like to mount it in the same spot,(circled thing in photo).
Thanks,
Matt
Old Jul 30, 2005 | 08:58 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
If the filter you installed burst, it wasn't rated for the high-pressure of a TPI system. You should get some fuel-line repair kits and plumb in a stock TPI filter. You're lucky you didn't have a Carbecue!
Old Jul 30, 2005 | 09:46 AM
Vader's Avatar
Uhh, how about a stock AC/Delco TPI filter?
Old Jul 30, 2005 | 08:32 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Puralator baby!
Old Jul 30, 2005 | 10:50 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Shouldn't the fuel lines on an 87 T/A be coming in from the drivers side???
Old Jul 30, 2005 | 11:07 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Mine are on the passenger side just like the battery as you can see. How easy would it be to put the stock filter in the same spot as the aftermarket one?.....Actually I know why the fuel lines are on the passenger side, I swapped the 305 carbed engine with the 350 tpi setup.
Old Jul 31, 2005 | 07:29 AM
Rob Wade's Avatar
You need to be running a fuel filter capable of handling 60+ psi of fuel pressure. TPI uses more fuel pressure than TBI or a carb.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
