TPI manifold gaps?
Old Jul 30, 2005 | 07:32 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
TPI manifold gaps?
I'm in the middle of swapping over a TPI system into a 1993 Caprice wagon. The new heads are AFR195's There is a visible air gap between the manofold and the intake ports. The manifold doesn't cover the whole port!
Would an Accel or Edelbrock TPI manifold be any better? If so, please detail why and which part #
Thanks! Dave Buchholz, Rochester NY
You can email at : lakeffect@gmail.com
Old Jul 31, 2005 | 12:19 PM
Vader's Avatar
Are these AFRs Vortec type heads?
Old Aug 2, 2005 | 03:31 PM
robert1's Avatar
They must be. I used standard AFR's 195 on the stock manifold ok. I even opened them up a little too for better flow.
diana227vegas
Jul 8, 2016 12:27 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
