New e/t's!!
Old Aug 1, 2005 | 05:39 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
New e/t's!!
Very impressed with the car this weekend. The GTA loved the air, I went consistent 12.5x's all weekend with a best of 12.497. My mph's were in the 108-109 range all weekeend with a best of 109.99, so close to 110!!
The weekend before I took home the trophy from our local Street Class Street Car Shoot-out. Street Class is 12.50 or slower heads up racing. It's great to be having fun with the car again!
So now my dyno results are really bafling me. Since my dyno pull of 280hp and 400tq to the wheels my car keeps getting better and better. There's no way I am only making 280 with those e/t's and mph's. Especially with a 3670 race weight. I think I will go to a different dyno next time.
Old Aug 2, 2005 | 10:04 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
What all does your car have done to it? Anytime a 12 second car comes up with a 12 second run, the engine set-up should always be shared not just times. It gives comparison to different set-ups.
Old Aug 3, 2005 | 04:03 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Sounds like u have a pretty good package going there.
Let us know the combo and your 60 fts.
What kind of ecm tuning?(assuming still injected?)
later
Jeremy
Old Aug 3, 2005 | 02:26 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I agreee , you arent makeing only 280 rwhp . I have 251 and 318 tq
but only mustered a 14.4 untuned . yeah lets hear this setup
Old Aug 3, 2005 | 02:41 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You have my attention, now for some details.
Old Aug 3, 2005 | 03:21 PM
kevinc's Avatar
Car: 1982 Z28
Originally posted by 305TA85
what all does your car have done to it.
Glancing to your left, just under his screen name, you'll notice he's got a 383 in it...
Anytime a 12 second car comes up the engine set-up should always be brought up not just times.
I feel the same way about using decent grammar.
Old Aug 3, 2005 | 03:34 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Good job bud! Just for reference I have several runs 13.6/13.7 @ 106-107mph. Dyno results naturally aspirated (April this year) was 364 hp / 376 ft-lbs @ rear wheels. Your MPH indicates more than your dyno results. I still suck at trying to launch this manual tranny with street tires (had a 116mph trap speed with an e.t of 14.2! - kind of a squirelly ride).
My race weight is a piggish 3,850 lbs but I still carry all of the creature comforts.
My combo is similar to speed88's (Brian I think?). He has a 383 miniram with a cam in the 230ish duration at .050.
Cheers,
-Schultzy
Old Aug 3, 2005 | 07:09 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Using the calculators available and plugging in the numbers the following came up.
Using speed and your race weight it showed 381 horsepower.
Using time and your race weight it showed 372 horsepower.
By the way very good times. I hope to be down a couple of ticks on my ET this winter. My race weight is 3760 so maybe you weigh a little less then me. Hehehehe.
Old Aug 3, 2005 | 09:47 PM
speed88's Avatar
Engine: 383
Wow! One day no replys, then the next all this!
Ok..my combo is a 383 stroker. All forged bottom end balanced to 8000rpm. LT4 Hotcam (218/224, .525"/.525", 112 LSA). Ported WP Torquer heads. Miniram. BBK 58mm tb. MSD everything! Edelbrock shorties. CAI. Ported MAF. SVO 30lb'ers. 3000 stall. B&M shift kit, servo, and clutch packs. 3:73's. Torque Arm, LCA's, etc, etc. PCMFORLESS tune.
That is the meat of the setup. I dont think I missed anything, but I might have..I am half asleep here! :P
I am very pleased with my numbers considering the small head and cam package on my motor. There is a story as to why they are there, I wont get into that right now. Feel free to ask any questions!
Thx for the interest.
Old Aug 3, 2005 | 09:49 PM
speed88's Avatar
Engine: 383
Oh, and my best 60' is a 1.672 with normal 60's in the 1.71-1.69 range.
Old Aug 3, 2005 | 09:52 PM
speed88's Avatar
Engine: 383
My race weight is also 3760. That was a typo by me in my the other post..sorry.
Old Aug 3, 2005 | 10:25 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I don't know, you're nailing the launch quite well w/ great 60 foots and have a mountain of torque, so you're getting a good number in the 1/4 but I don't think 109mph equates to much more than 280-300 rwhp. You've got those somewhat lackluster heads, I'm just thinking a crapload of torque and decent but not stellar rwhp numbers are not out of line w/ a 12.5@109 w/ a pretty awesome launch of 1.70 or better 60'...
If you were on street tires cutting 2.0-2.1 60's you'd be back up in the 13.0 range w/ a similar trap speed, right in range with what 280/400 at the rears oughta hit IMO...
Are you serious or is there a typo there, you're numbers don't seem to jive with your 1/4 time/mph at all to me, even with the weight?? Uncorrected 1/4 numbers from a highish altitude/DA track yet corrected dyno numbers maybe??
Old Aug 4, 2005 | 12:20 AM
Car: 1989 GTA
No typo Ray. I think you have underestimated just what a crappy driver I am
Actually those track times were the same day as the dyno. Near sea level. Track times and dyno are corrected.
It had been pouring rain all day before the track opened. I was parked in a freaking lake in the staging lanes! All that to say that I think I was spinning much more than I knew. The silly 14.2 run mentioned above was on spray and the back end kicked out after I shifted into 3rd. That was, ummm, exciting.
Had plenty of other cars that dynoed, some known combos that had been run on diff dyno's so I think the dyno was pretty accurate.
Sorry to clutter up your thread speed. I forgot that your cam was smaller. Nice track times
-Schultzy
Old Aug 4, 2005 | 08:24 AM
speed88's Avatar
Engine: 383
It's all good Schultzy!
I know my e/t's are pretty good considering my small head and cam. I am looking forward to what a decent set of heads will do next year, and I might throw in a cam if the budget can handle it. In other words if the wife doesn't want to fly south!
Old Aug 8, 2005 | 06:26 AM
rcwest32's Avatar
Why are all these cars so heavy?? I thought average weight was 3300? You know you're only supposed to take a few hand tools to the track, not your whole roll a round box
Old Aug 8, 2005 | 07:57 AM
speed88's Avatar
Engine: 383
That is the weight of my car. Most of these cars are that heavy or heavier! My car at that weight has some weight redeuction, no a/c upfront, and no spare tire or jack in the back.
Old Aug 8, 2005 | 10:37 AM
rcwest32's Avatar
I hope that's with you in it!
My buddy had one that we weighed, it came in at 3357, no driver and just enough gas in the tank to register, but it had just about all the options. This was an '88 IROC, if that matters.
Old Aug 8, 2005 | 11:33 AM
firebirdjones's Avatar
weight
Ya I was wondering the same thing, my 88 Iroc L98 with all options and 1/2 tank of gas weighed only 3440 lbs. and I weigh 200 so thats 3640 race weight. Why are the rest of these cars heavier? Just curious. Larry.
Old Aug 8, 2005 | 02:19 PM
speed88's Avatar
Engine: 383
All right....ya caught me! LOL! I'm not exactly a spring chicken here! My car without me weighs 3400. With me the car wighs 3670, I was right the first time.
Gee, I'll give $5 bucks to the guy or gal that can guess my wieght to within 10 pounds!
Old Aug 8, 2005 | 02:58 PM
Car: 1989 GTA
Engine: 369 TPI
My 1989 GTA weighs in at 3510 pounds with a 1/3 tank of gas. Has all the options including T-Tops. The GTA's are the heaviest of the 3rd gens. My race weight is 3760.
Old Aug 8, 2005 | 04:00 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
My 1989 GTA weighs in at 3510 pounds with a 1/3 tank of gas. My race weight is 3760.
SLIM-FAST!
j/k
Old Sep 16, 2005 | 01:53 AM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Wow my berly ways 3160 with cast iron heads and water pump and full size starter and exhaust manifold, with a steel hood with a 1/4 tank of fuel. I wonder what my car would run with that combo, but with a fiberglass hood aluminum waterpump, mini starter, headers and aluminum heads?
Wow I dream of a 3rd gen that runs in the 11.90 area and knocks down good milage(6speed of course)
Is it possible?
Thanks Randy
Old Sep 16, 2005 | 06:16 AM
mileage
I think it's very possible Randy, just depends on what you consider as "good mileage" Larry.
Old Sep 16, 2005 | 09:57 AM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Randy, Just start saving up for a LS2 and drive tran. hahah
I hope to LS1/6 speed/computer/ my Vette one day rather then putting a stroker motor and all that other stuff.
Old Sep 16, 2005 | 02:32 PM
rcwest32's Avatar
Uh mmmmm....270?? LOL
Old Sep 16, 2005 | 07:37 PM
no, i wont even consider an LS2. If Im going to dream it will be the
the new 2006 Zo6 505 hp!!!!!!
Old Sep 17, 2005 | 03:23 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The magnum TPI project in GM high-tech perf. mag. went 11.99 @ 111 mph, if I remember right and it only made ~337 rwhp.
Point is: torque does mean something and HP is important, but HP isn't everything.
Just the 2 cents.............
Old Sep 19, 2005 | 09:26 AM
8UpAFord's Avatar
Car: 1988 Corvette
Old Sep 19, 2005 | 12:24 PM
speed88's Avatar
Engine: 383
Update: As you can now see from my sig my new best is a 12.41 @ 111.02 mph on the motor. And with a rich 75 shot I went 11.85 @ 114.03 mph. It was a rich fuel shot.
Old Sep 19, 2005 | 03:55 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Sweet times !! Looks like I'am not the only +270 pound GTA owner
Old Sep 19, 2005 | 08:10 PM
speed88's Avatar
Engine: 383
Originally posted by Tony89GTA
......Looks like I'am not the only +270 pound GTA owner
Welcome to the club!
We're a little far away to go for a run though, I'm all the way over here in St. John's NL. It'd be a sweet cruise though....I wonder how fast I could get to B.C.?
Old Sep 19, 2005 | 08:56 PM
Car: 1989 GTA
Congrats on the 11's bud.
-Schultzy
Old Sep 20, 2005 | 10:42 AM
Wow that is moving. my goals are high to mid twelves with my berlinetta all motor
myh0
Theoretical and Street Racing
Apr 4, 2002 09:03 PM
lonsal
Southern California Area
Jan 28, 2002 01:01 AM
1989Formula350
Nov 10, 2001 01:50 PM
chevyboy07 91
Sep 6, 2001 12:55 AM
ws6transam
Jan 31, 2001 07:18 AM
