Help! Fuel leaking out of fuel tank vent line
Old Aug 2, 2005 | 08:49 AM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
I have a problem I can't figuire out. Of the four lines coming off of my fuel tank, I know one is fuel feed, one for fuel return, one goes to the charcoal canister, and the other I think is a vent(it is connected to just a small plastic filter or check valve. It is that short line with the plastic valve on the end that is leaking. I pulled the valve off and gas poured out of the line. I can't understand why there is that much fuel in the line. Any Ideas? Please help!
Old Aug 2, 2005 | 01:34 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
The fuel tank vent valve is there only to let air into the tank to displace the fuel used.
If it is leaking, it is either bad and letting gas out or you have a purge malfunction issue which is letting excessive pressure build up
later
Jeremy
Old Aug 2, 2005 | 02:42 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
It must be a purge issue or something, bacause there is a lot of fuel coming from the line. It hapened once before, I thought it was because I overfilled the tank. I drained the vent line, and it stopped for a while. The problem is back now, though.
Next question, how do I diagnose the purge problem and fix it?
Thanks for the tips, keep them coming!
Old Nov 8, 2013 | 09:33 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Re: Help! Fuel leaking out of fuel tank vent line
Did you ever fix this...it just happened to me
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
