2nd fan not comming on
Old Aug 13, 2005 | 07:08 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I recenlty just changed the plugs on my car and knocked a wire loose. I don't remember exactly what it looks like, but I have heard that this sensor makes the 2nd cooling fan come on?
Is that the right part for what I need? Is it a clip or a screw in type? If it helps, the wire i knocked loose was right next to the 3rd exhaust port of the drivers side, not sure if it was on the head or the block.[IMG]
Old Aug 13, 2005 | 09:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Guessing you're referring to the connector on the pass side head below and between #6 and #8 plugs?
If so, it is the 2ndry fan sensor (ala coolnat fan switch).
I don't recall what my stock (on my '89 IROC) switch had, but do recall I used a spade connector for the hypertech switch I replaced it with.
FWIW, the pic you show looks exactly like the stock fanswitch in my '91 RS
Old Aug 14, 2005 | 08:51 PM
Well, i touched it back in the hole when replacing my plugs, and the fan came on for a second, so im guessing what that is. (that pic was from a tbi related post)
Old Aug 14, 2005 | 10:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, the RS I have is exactly like your pic posted, but it's been so long since I changed my origianl fanswitch out (in my IROC), I don't recall what it looked like..I do know I had to put a spade connector on the wire to work with the Hypertech one I used...
Lotta good that does ya, huh?
Old Aug 14, 2005 | 10:56 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: 2nd fan not comming on
Identical to my '88 IROCZ's heavy duty fan relay switch on the passenger side between cyl. 6 & 8.
Old Aug 15, 2005 | 01:51 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Get the high speed fan switch for a 86-87 or 89 Buick 3.8 Turbo application.
Bout 14$ and turns on the second fan at 203-205 instead of assinine 237 degree like the stocker does :-)
later
Jeremy
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
