fuel injector questions
Old Aug 15, 2005 | 12:45 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Are they all created equal ? I bought a new set quite sometime ago and the car has never run right. I told the parts store they were for a VIN code 8 engine (first mistake since this is a 305) however I'm switching to a 350 soon here anyways. Heres the biggest question .... these injectors were of the 87'ish ordered vintage and I went to speed density instead of using mass air as I originally planned. Would the older injectors cause a problem with the 90-92 730 ECM.
Old Aug 15, 2005 | 12:55 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
They shouldn't. I'd bet the problem right now is your running 22# injectors and the system thinks you're running 19's. Does the exhaust smell or put black spots in the dirveway if you let it sit and idle for 5 minutes after sitting overnight? Are the plugs getting blackened? Those would be sure signs of what I'm talking about....
Old Aug 15, 2005 | 03:35 PM
Jproz1167's Avatar
no it doesn't leave black spots at all, but then again it has a catalytic converter as well. The car does make alot of popping sounds in the exhaust though. I know the car is running on the rich side though.
Old Aug 16, 2005 | 12:41 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I swapped in a set of 22 lb injectors out of a 88GTA with a 350, into my 305 tpi. It ran fine and I even passed smog a few months later with it, no tuning what so ever.
While datalogging I noticed it ran a little rich whenever the rpms changed, but that was only a second or two, then it would pull out fuel and be right where it should be.
All the injectors (from thirdgens) are the same high impedence injectors, so it should cause no problems, however the injectors in the later years were junk, I believe they changed over in 89.
If you're going to put in a new engine, I would send the injectors out to Rich at Cruzin' Performance, and have him check them out and service them, he could tell you if there are any problems with the injectors.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
