Stalling problem
Old Aug 17, 2005 | 09:13 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
Stalling problem
My car keeps on stalling and i can't figure out why. it's a 350 stealth ram car with alum. heads, other aftermarket parts, and a custom chip. for some reason, the car will stall and will not restart after it stalls. i tested the tps and it's fine. i'm thinking that it might possibly be the map sensor. i just replaced all of the plugs, wires, cap, and rotor. if anyone has any ideas, please let me know. thanks
Old Aug 20, 2005 | 08:26 AM
Vader's Avatar
Are all error codes enabled in the programming?
Are you getting any codes?
You can test the MAP sensor with a vacuum gauge or handheld vacuum pump and voltmeter. Attach the voltmeter to the MAP, apply the vacuum, and compare the voltage output:
Old Aug 20, 2005 | 06:33 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Yea sorry I wasn't more specific when i posted. i'm not sure if the chip was burned to ignore trouble codes and no i did not recieve any. i re-posted with a more specific description under the general tech and engine tech board.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
