Misfire at WOT
Old Aug 18, 2005 | 06:52 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
Misfire at WOT
my friend just put a new cam is his car(.525 lift and 250 dur. at .050) with 1.65 rr's he got a valve job, lt's, and true duals, 30 lb injectors, msd coil and wires. his car is pretty fast at like 1/2 throttle but when it is at WOT is misfires horrible. its a 1985 iroc with a 350 tpi( yes it is a 350) and 700 r4. anybody wanna take a stab at whats wrong?
Old Aug 18, 2005 | 07:28 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Stab..
Fuel pressure dropping cuz pump can't provide enough.
Didn't change the prom to reflect the VE changes.
Valve springs changed to match???
Old Aug 19, 2005 | 11:21 AM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
valve springs were changed alone with kepper,s retianers, etc. should check the fp now. it mighjt b the prom hes shouls be getting one from pcmforless.com soon
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
