TPI idle speed
Old Aug 21, 2005 | 07:01 PM
Camarothunder85's Avatar
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
TPI idle speed
I read the tech article and it said the idle speed should be 600 rpm, but when my car idles at 600 rpm the voltage drops. Am I just reading the article wrong? What should the idle be set at?
Old Aug 22, 2005 | 09:55 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That 600 rpms is for a stock engine. Since you have a 350 in an 85, the tech article doenst apply to you. Your idle speed depends highly on how big your camshaft is. More cam needs a higher idle.
Wade787b
Sep 29, 2015 01:15 PM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
