Need help with TPI vacuum lines near dizzy
Old Aug 23, 2005 | 08:16 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Attached to the bracket which also mounts the remote coil, is a plastic molded piece with two vacuum lines and a 2 wire connector. The 2 vacuum ports lay fore & aft to the front of the car. Both came disconnected when I recently pulled the dizzy.
Which line goes where?
I think one line goes up under the plenum and to the T under the TB, maybe.
The other line might go to the EGR, maybe.
Can someone help me get these hooked up correctly? I know you are out there.
Old Aug 23, 2005 | 09:33 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
doc,
you are correct. the aft most one goes to the egr and the foremost goes to the "t" under the throttle body
Old Aug 24, 2005 | 05:42 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you.
There are so many tubes and wireing, that it is difficult to remember where they all go and should be routed.
Old Aug 24, 2005 | 05:45 PM
87zjeff's Avatar
no problem doc. i had to go out and look on mine myself. i'm hoping that someone might have an upper plenum they would be willing to part with. wanting to port one then install.
junkcltr
Aug 2, 2019 11:12 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
apie2546
Aug 10, 2015 05:43 PM
