what kind of fuel pressure should I be running?
Old Aug 31, 2005 | 06:35 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
I have 30# injectors...what kind of fuel pressure should i be running?
Old Aug 31, 2005 | 10:54 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
I would guess 35 w/ vac, low 40's without....
... and burn the chip accordingly. I really doubt you can throw a much larger set of injectors on a 355 and hope to dial pressure down far enough to compensate effectively. Anything much below the low 30's and the spray pattern begins to really suffer with those little guys.
Old Aug 31, 2005 | 04:59 PM
Car: 1991 Z28
Engine: SBC
ok now with the fuel pressure guage...i attach to to the shreadder valve...do i pull the vac line off the fuel pressure reg? and stick it on the fuel pressure guage?
and yea i have my prom set for 30's
Old Sep 9, 2005 | 04:28 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
The vacuum line remains attached to the fpr.
92camaroJoe
Jul 29, 2023 07:57 PM
pimp2303
Jul 27, 2017 02:03 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
