need help
Old Aug 31, 2005 | 05:33 PM
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
need help
would like to say hey to everyone and that this site kicks ***!
i have a problem with my car idleing. normal driving its fine but if i floor it and then when i let off it becomes real stumbely and shake, sometimes stalls. since this started happening the car seems like it has lost some power. i have been told either knock sensor tps or iac checked for trouble codes and there are none
thanks
Old Aug 31, 2005 | 09:03 PM
SSprayd's Avatar
Car: '97 30th SS, '89 IROC-Z
Engine: LT4, LT1
Transmission: T56, 4L60E
may be a fuel pressure problem, fuel pump may be messing up a little.
Old Sep 1, 2005 | 01:14 AM
Engine: 305 tpi
could be..............it had 2 trouble codes when i got it, one for maf and 1 for esc, the maf connector was a little loose so solved that but the esc trouble code just vanished 1 day
Old Sep 1, 2005 | 03:39 PM
Engine: 305 tpi
anyone else have suggestions
Old Sep 1, 2005 | 06:52 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
vacuum leaks and dirty fuel logs and injectors
