what's that noise?
Old Aug 27, 2005 | 10:10 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
what's that noise?
Started the GTA up last night after a 2 week sit and was checking under the hood for some reason and heard a weird noise.
The noise is coming from the driver's side valve cover area and basically sounds like a marble being tossed around inside a tin can. It's not constant, doesn't have a normal pattern, and has never been heard there before.
I drove the car for a bit (needed a car wash) and the sound got quiter but it's still there.
Any clues? Is it finally time for that rebuild? Is it the good ol' "heartbeat of America"?
Old Aug 28, 2005 | 03:07 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
pull your valve cover and check that all your rocker arms are tight. also crank it a few times with the valve cover off and recheck it.
does your car have any other symptoms?
Old Aug 31, 2005 | 09:20 PM
SSprayd's Avatar
Car: '97 30th SS, '89 IROC-Z
Engine: LT4, LT1
Transmission: T56, 4L60E
worst case it might be a lifter but possibly a rocker arm as well.
Old Aug 31, 2005 | 10:35 PM
Car: 1987 GTA
Transmission: 4L60e
I'm going to be checking it out this weekend. Hoping it's not much...but then again...ideas of a 383 with trickflow heads and a super-ram dance in my head when things like this happen.
Old Sep 1, 2005 | 12:17 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
if you got the money for the 383 say goodbye to your current engine. if you just need encouragement to do it well then here it is. your whole engine is screwed. might as well just go out and buy a new one. if your going to buy a new one might as well do it right.
Old Sep 1, 2005 | 09:14 PM
Car: 1987 GTA
Transmission: 4L60e
lol...thanks...I think
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
