Afpr
Old Sep 3, 2005 | 11:38 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Afpr
Ok thought I would throw this out there. I am in the process of running an aeromotive fuel pressure regulator. The one question I have is if I do this can I get rid of the return line comming off the fuel rail? I will still have a return but it would be like the ls1 and not be in the rail. I think this would work but thought I would throw it out there and see.
Old Sep 5, 2005 | 11:00 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If the Aeromotive regulator is in fact returning the fuel to the tank, then yes, you would only need to run one fuel line to the TPI rail, and the rail mounted regulator would probably act as a pulsator (pulsation dampner). You will need to block off the return line from the rail.
Just out of curiosity, why would you want to do this?
Old Sep 5, 2005 | 01:01 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
To have more fuel pressure control. I decided to build my fuel system this year with an aeromotive pump -8 feed line and aeromotive recomends there regulators to be used with there fuel pump.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
