maf sensor bypass
Car: 1985 trans am
Engine: 5.7 tpi
Transmission: 700-r4 with b&m trans pack
maf sensor bypass
i have an 85 t/a with the 305 tpi, is it possible to bypass the maf so i can put a different air intake on it, if not is there a true cool air intake i can put on it?
Car: 89 Irocz
Engine: 350TPI $6E
Some guys in the DIY PROM section have swapped some code on the chip to convert to run SD instead of the MAF. I don't think it's difficult, but you need to be able to burn your own chip and make some code changes with a hex editor to your bin file.
https://www.thirdgen.org/techbb2/sho...hreadid=112882
https://www.thirdgen.org/techbb2/sho...hreadid=309497
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
That MAF conversion to MAP using the stock ECM is brilliant. I did the conversion and had to get a new computer and whatnot. Why try to remove a working MAF? If you want cold air intake just keep it plugged in and get some more piping and make your own- keeping the MAF in there somewhere.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Personally, I would swap to the '730 ECM. That way there is no MAF and you have the benefit of using the ECM with the most DIY info available for tuning, etc.
It is pretty easy to do...
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
