Do cold air intake and unbolted catback increase or decrease mpg?
Old Sep 10, 2005 | 04:27 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I want better mpg. Is my cai and unbolted cat-back eating more gas or eating less because the engine is more efficient?
Also I want to get a new fuel filter and do that acetone stuff and see if that helps. The car is in good shape and runs fine. I also will get an oil change as well.
But should I bolt my catback up and remove my cold air intake?
Old Sep 10, 2005 | 07:29 PM
mcwpns's Avatar
Car: 1989 firebird/91 tpi formula
Engine: 327 small block/305 tpi
Transmission: 700 R4
Axle/Gears: superior axles/3.42's
I would say to keep the cold air intake but I'd bolt up the cat back. I did a bunch of chassis dyno's at my school and when we would remove exaust we would gain upper rpm hp but it would kill the low end torque. If your looking for gas mileage your best bet would be the torque at part throttle driving. The cold air intakes help all the way around due to a denser air charge.
Old Sep 10, 2005 | 08:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Read for every 10 degrees drop in air temperature you gain 1% in horsepower as a rule of thumb.
Old Sep 10, 2005 | 10:05 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
My husband says they will decrease your mpg.
Old Sep 10, 2005 | 11:07 PM
DanTheMan_smlk's Avatar
a catback and intake will certianly help your mpg but only if you accelerate at the same rate as before. If you get this stuff and go flooring it all the time, you wont notice an increase really
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
