LT1 Throttlebody
Old Sep 12, 2005 | 02:33 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
LT1 Throttlebody
What are the differences between the 90-92 TPI and LT1 throttlebodies? I know that the way the TPS is mounted is different. Could a LT1 throttlebody be modified to work with the TPI TPS?
Old Sep 13, 2005 | 05:16 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
TPS and IAC are both different. I don't see a reason why you can't make it work. You will need to use the appropriate coolant plate (lower half of the throttle body), as it is different from a TPI car.
Now that I think about it, if you use a TPI coolant plate, you can use a TPI IAC valve. So the difference would just be the TPS.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
