TPI intake torn ? please check !
Old Sep 16, 2005 | 01:44 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Hello,
Is my TPI intake torn ?
oil is leaking from that "space"..
please check pics below
can i fix this ? or must i install a new intake..
don't have enough money know..
is this a good alternative to replace my stock
intake if i can't fix this.... :
http://cgi.ebay.com/ebaymotors/Accel...QQcmdZViewItem
US $367.99... are there cheaper intakes ??
i ve ever seen an intake, with hidden nitrous for 350 dollars
on ebay... now they don't exist ..
please give me you help ASAP !
give me some good links where i can purchase a new intake
if cheaper or better, with hidden nitrous.
thanks
Old Sep 16, 2005 | 02:48 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Are you sure that is oil? That looks like old fuel from the shrader valve or pressure regulator. Kind of hard to see in the pics.
Old Sep 16, 2005 | 05:14 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
JB WELD!
LOL. Seriouisly though, it doesnt look cracked to me. Check your valve covers, or clean the area really good, and pour just a tad bit of water over the suspected crack, with the engine completely cool so the heat dont evaporate it and make you think it is a hole. If the water goes down inside, then its a crack. If it dont, and just sits there for the next 2 hrs, dont worry about it.
P.S. any vacuum problems? There would be a leak if it was cracked also. Hook up a vacuum gauge and test it.
Old Sep 16, 2005 | 05:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I see coolant. I would be more worried about that leaking lol. Ya JB weld it if its cracked.
Old Sep 16, 2005 | 05:51 PM
GTA89's Avatar
Engine: 5.7 350
hello guys !
thanks for reply,
no no no :-)
the intake is recently installed,
there is no leaking from the intake, where the seals are.
the coolant you see, is my fault, i did that..
i ve cleaned the area where the red arrow points..
i m very sure that the oil is leaking from this space...
before i removed the runners and other hoses they were all clean
only AT the intake, where the red arrow is there was oil ON it.
i think its coming from the space, i m sure its oil.
but how can i fix this now, or should i replace it ?
and one more thing, the car runs excellent,
i m just worried about the oil leaking from that
small horizontal space..
and if i weld it, for how long can i trust this ?
because i want to drive with the car from the Netherlands to
France. going to Euro Disney yeah, you know.. my wife...
Old Sep 16, 2005 | 06:02 PM
GTA89's Avatar
Engine: 5.7 350
Originally posted by PneumaticTire
JB WELD!
hey !
hmmmm the valve covers. thats is possible..but its seems new.
i will put all the parts together, run the car and try to record
it with my video cam... so you all can see it... okay,
see ya later
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
