Took the TA to the track tonite
Old Sep 17, 2005 | 12:00 AM
koll's Avatar
Car: 1991 Pontiac T/A Vert
I just got my new 1991 T/A Vert with 350 TPI on wednesday. Took it to the track today. I wasent too pleased, my best was 15.2 @89. I hooked up good. Its bone stock except for SLP Y pipe with random tech. cats, SLP headers, Hooker aero chamber cb 3" all the way. I could feel the TPI running out of breath at around 4k. Any ideas? The 350 is out of an 89.
Old Sep 17, 2005 | 02:20 AM
NEEDforSPEED's Avatar
i told you, lt1 intake and a tune
Old Sep 17, 2005 | 09:05 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Not to mention your vert weighs as much as a dump truck. What elevation is the track at??
Old Sep 17, 2005 | 02:35 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
those times are about right for a stock L98, maybe a tad slow. But If im not mistaken, a vert wieghs more than a ttop car, so that could affect it also. If you car is running out of breath, port you plenum and base, and get some SLP runners, that would help the topend a bunch mixed with those headers. What gears are you running? I would suggest 3.27s or 3.23 (whether its a 9 bolt or 10) for optimal launch, cruise ect. Also do a good tune. Hope this helps.
Old Sep 17, 2005 | 05:20 PM
koll's Avatar
Rearend is stock, so whatever gears are in a 91 305. As for weight, it weighs 3900 with me in it (yes, I could cut off a good 2-3 seconds if I was 150 lbs). Ive been getting in contact with a guy from NJFBOA about tuning.
Old Sep 17, 2005 | 09:58 PM
Guest
Guest
Posts: n/a
I dont know about them being that much heavier. Mine is totally stock 89 GTA w/350 and I ran back to back 14.9's@93 with it. I am pretty sure I can do better with a decent 60' and a tuneup that it does need.
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
