cleaning engine bay on my 85 z
Old Sep 17, 2005 | 01:03 PM
V6camaroman's Avatar
hey guys im about finished with my motor rebuild on my 85 z thats got the 305 tpi motor. right now i have deleated the emmisions and AC on the car and i want to know what else i can safely take out of the engine bay to reduce cluttering. i was wondering about the cruise control unit and there is also some other vaccum box i think on the driver wheel well. can i remove both of them? also i have deleted the heater box what can i do to remove the relay and wires that once went to control the heater system? any ideas would be apriciated thanks
Old Sep 21, 2005 | 10:07 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Is the other vacuum thing your talking about cylinder shaped? its more smog crap you can get rid of. You can always take the washer fluid reservoir out. Get a serpentine setup with an ac delete pulley will make it look better than those old vbelts. you can always just cut the wires? well what I did was make a block off plate from a piece of tin, paint it the same color and stuff all the wires behind it under the dash. That clears it up a lot.
Old Sep 21, 2005 | 12:10 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
I think it looks cleaner w/ the V-belt. You dont need to deal w/ any idler pullies. The cruise control can come out easily enough if you dont use it much go for it. That cylinder next to it is the evap canister. You can remove it but make sure you dont plug the line comming from the gas tank, you dont want pressure to build up. I just ran som rubber hose from the line into the fender well.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
